I have Agilex™ 7 FPGA I-Series Transceiver-SoC Development Kit that i want to use to transmit an PRBS9 pattern at 56G NRZ. Then on the receiver side i want to be Able to calculate the Bit error rate to judge the quality of the link.
I noticed the BTS GUI comes with some xcvr example for 56Gbps pam4, 100Gbps pam4 and 25Gbps NRZ. There is no 56Gbps NRZ examples. I tried to modifying the 100Gbps xcvr example and to make it run at 56Gbps NRZ however when I try to load the newly compiled sof with BTS GUI i get the following warning.
"The design running on device is incompatible with related design within image folder"
I have a lot of SerDes experience but i am new working with FPGAs.
1. Is there another example that i can follow to create 56Gbps NRZ transimitter or receiver? With GUI similar to the BTS.
2. Is modifying a BTS example even an option? Or are the BTS examples just fixed and cannot be edited.
Would greatly appreciate any guidance on whats the right approach for this task.
Yes my issue is resolved. Found out about "System debugging toolkits" and looked up the documentation on it.
Hello
Welcome to INTEL. We sincerely apologize for the inconvenience caused by the delay in addressing your Forum queries. Due to an unexpected back-end issue in our system, your Forum cases, along with others, did not get through as intended. As a result, we have a backlog of cases that we are currently working through one by one.
To further check, may we know whether your issue has been resolved, or if you're still encountering any problems?
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to https://supporttickets.intel.com/s/?language=en_US , view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
