I'm trying to compile pcie_ed from agilex_agib027r29a1e2vr0_fpga_reva_v21.2b072_v1.0/examples/pcie_ed
using Quartus Pro 21.
Opening the project, running the compilation:
Could you provide working example with at least no error when compiling...
1. Download here
it says "21.2 or higher"
2. I untar pcie_ed, pcie_ed.qpf has QUARTUS_VERSION = "21.1"
3. Open the qpf with Quartus 21.1, compile, errors
Please update the link ASAP with working examples.
From the same tar, I tried to compile "qsfpdd_xcvr" on 21.1 (on 22.1 the Avalon Data Test Generator IP core doesn't exist...)
I don't find this error message very useful, any help would be very much appreciated.
Opening the "Support-Logic Generation" 's report, Quartus ends up crashing:
Problem Details
Error:
*** Fatal Error: Segment Violation: faulting address=0x10, PC=0x7f1a2607a6bd : 0x7f1a2607a6bd: db_tileip!TILEIP_WRITER::initialize_default_profile() + 0xc1
Module: quartus
Stack Trace:
Err Handler 0x111ab: ERR_UNWINDER_BACKTRACE::get_stack_trace(void const**, int, int, void*) + 0xf3 (ccl_err)
Err Handler 0x7429a: msg_ie_get_call_stack(void*) + 0xa3 (ccl_msg)
Err Handler 0x7588e: MSG_INTERNAL_ERROR::report_fatal(char const*, void*) + 0x3c (ccl_msg)
Err Handler 0x12b2d: err_report_fatal_exception(char const*, void*) + 0x68 (ccl_err)
Err Handler 0x135e6: err_sigaction_handler + 0x12f (ccl_err)
System 0x12ce0: (pthread)
Quartus 0x3d16bd: TILEIP_WRITER::initialize_default_profile() + 0xc1 (db_tileip)
Quartus 0x4093d8: TILEIP_WRITER::solve_tile(std::vector<std::pair<std::string, std::string>, std::allocator<std::pair<std::string, std::string> > >*, TILEIP_TILE*, std::string const&, bool, bool) + 0x4a (db_tileip)
Quartus 0x40973f: TILEIP_SOLVER_IF_IMPL::validate_placement(std::vector<TILEIP_SOLVER_IF::TILEIP_BB_PLACEMENT, std::allocator<TILEIP_SOLVER_IF::TILEIP_BB_PLACEMENT> >*, std::string const&, bool) + 0x133 (db_tileip)
Quartus 0x40094: TPL_FACADE::load_ip_json(std::string, nlohmann::basic_json<std::map, std::vector, std::string, bool, long, unsigned long, double, std::allocator, nlohmann::adl_serializer, std::vector<unsigned char, std::allocator<unsigned char> > >) + 0x104 (sys_tpl)
Quartus 0x7b78c: BPPS_MANAGER::load_design() + 0x440 (sys_bpps)
Quartus 0x7d90e: BPPS_MANAGER::initialize() + 0x32 (sys_bpps)
Quartus 0x60688: bpps_initialize_blueprint + 0x2e7 (sys_bpps)
Quartus 0x4c942: TclNRRunCallbacks + 0x42 (tcl8.6)
Quartus 0x4de7b: TclEvalEx + 0x68b (tcl8.6)
Quartus 0x4e496: Tcl_EvalEx + 0x16 (tcl8.6)
Quartus 0x1e3d9: atcl_tcl_eval(Tcl_Interp*, std::string const&, bool) + 0xe3 (ccl_atcl)
Quartus 0x6d718: ITC2_BPPS_CHANNEL_IMPL::doWork() + 0x598 (resr_itc2)
Quartus 0x6bdd1: ITC2_BPPS_CHANNEL_IMPL::qt_static_metacall(QObject*, QMetaObject::Call, int, void**) + 0xf1 (resr_itc2)
Quartus 0x2db023: QObject::event(QEvent*) + 0xd3 (Qt5Core)
Quartus 0x15b7ac: QApplicationPrivate::notify_helper(QObject*, QEvent*) + 0x9c (Qt5Widgets)
Quartus 0x162290: QApplication::notify(QObject*, QEvent*) + 0x1e0 (Qt5Widgets)
Quartus 0x2aba18: QCoreApplication::notifyInternal2(QObject*, QEvent*) + 0x108 (Qt5Core)
Quartus 0x2aea92: QCoreApplicationPrivate::sendPostedEvents(QObject*, int, QThreadData*) + 0x222 (Qt5Core)
Quartus 0x304851: QEventDispatcherUNIX::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) + 0x41 (Qt5Core)
Quartus 0x2aa42a: QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) + 0x10a (Qt5Core)
Quartus 0xb52b4: QThread::exec() + 0x84 (Qt5Core)
Quartus 0x1b41cc: AFCQ_THREAD::thread_wrapper(void*) + 0xe (gcl_afcq)
Quartus 0x40ed6: msg_thread_wrapper(void* (*)(void*), void*) + 0x64 (ccl_msg)
Quartus 0x1528e: mem_thread_wrapper(void* (*)(void*), void*) + 0x5e (ccl_mem)
Quartus 0xcdc0: err_thread_wrapper(void* (*)(void*), void*) + 0x1e (ccl_err)
Quartus 0x6ba5: thr_thread_wrapper + 0x15 (ccl_thr)
Quartus 0x1b3855: AFCQ_THREAD::run() + 0x13 (gcl_afcq)
Quartus 0xb65a5: QThreadPrivate::start(void*) + 0x135 (Qt5Core)
System 0x81ca: start_thread + 0xea (pthread)
System 0x39d83: clone + 0x43 (c)
End-trace
Quartus Prime Version 21.1.0 Build 169 03/24/2021 SC Pro Edition
Hello
Welcome to INTEL forum. Can you give me a little background/elaborate on your setup proses and step? provide error messages?
For privacy, reply/attach your file in private message.
No need for privacy, I'm just trying to work with Intel's public projects.
1. https://www.intel.com/content/www/us/en/products/details/fpga/development-kits/agilex/i-series.html
2. Download the tar ES (21.2 or higher)
3.
3. untar
4. open with quartus pro 21.1 or 22.1
5. agilex_agib027r29a1e2vr0_fpga_reva_v21.2b072_v1.0/examples/pcie_ed or any other example designs
6. try to compile the project
the website is really broken, it doesn't stop to move the view down, it's pretty annoying and impossible to write a simple message...
Hi
Could you provide the error message screenshot and the .log file
Hi
Upon checking, the case is still in pending investigation by engineering. The fix will take some time. As suggested in community forum https://community.intel.com/t5/Intel-Quartus-Prime-Software/Avalon-Data-Pattern-Checker-IP-missing-in-Quartus-Pro-22-1/m-p/1390003#M73987
that is the best you could use back the older Quartus version which has the IP for now as a workaround.
We have not heard from you and I hope that my last note clears up this matter. I will now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
