6411 Discussions
[Agilex}:Issue with Ping Command on I210-T1 Ethernet Server Adapter
raju1421
Dear Intel Support Team,
@IntelSupport
we are encountering a problem in our Agilex SOC Development Kit, which is connected to an I210-T1 Ethernet Server Adapter.
The ping command does not yield any response when executed.
enp1s0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 172.16.21.23 netmask 255.255.192.0 broadcast 172.16.63.255
ether 00:1b:21:ee:54:5e txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 208 overruns 208 frame 0
TX packets 0 bytes 0 (0.0 B)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
device memory 0x90100000-901fffff
Error Details:
[ 47.851253] igb 0000:01:00.0: Detected Tx Unit Hang
[ 47.851253] Tx Queue <1>
[ 47.851253] TDH <0>
[ 47.851253] TDT <1>
[ 47.851253] next_to_use <1>
[ 47.851253] next_to_clean <0>
[ 47.851253] buffer_info[next_to_clean]
[ 47.851253] time_stamp <ffff0770>
[ 47.851253] next_to_watch <000000002d0c8805>
[ 47.851253] jiffies <ffff09c0>
[ 47.851253] desc.status <938000>
[ 49.834273] igb 0000:01:00.0: Detected Tx Unit Hang
[ 49.834273] Tx Queue <1>
[ 49.834273] TDH <0>
[ 49.834273] TDT <1>
[ 49.834273] next_to_use <1>
[ 49.834273] next_to_clean <0>
[ 49.834273] buffer_info[next_to_clean]
[ 49.834273] time_stamp <ffff0770>
[ 49.834273] next_to_watch <000000002d0c8805>
[ 49.834273] jiffies <ffff0bb0>
[ 49.834273] desc.status <938000>
Thanks & Regards
Satrasala Raju
raju1421
Hi Intel Communities,
Thank you for your response.
Here are the details you requested:
  1. Intel Ethernet I210 Specifications: I am using an Intel Ethernet I210-T1adapter(1Gbe,Single Port,Copper,RTL Single)
  2. Driver Version for Ethernet and igb: The version of this driver is 6.1.38-243710-g50b63a962d02-dir. The firmware version is 3.25, 0x800006eb.
  3. Kernel Version: The Linux kernel version I am currently running is 6.1.38-243710-g50b63a962d02-dirty.
Thanks & Regards
Satrasala Raju
IntelSupport
Community Manager
Hi raju1421,
Thank you for contacting Intel Communities.
Can you please confirm the Intel Ethernet I210 Specifications that you are using?
Kindly provide the driver version you are using for the Ethernet and igb.
Please also share the kernel version that you are using as well.
Kindly let us know if you have any questions.
Hayat
Intel Customer Support
raju1421
Thanks & Regards
Satrasala Raju
IntelSupport
Community Manager
Hello raju1421,
Kindly go thru this site Linux* Base Driver for Intel® Gigabit Ethernet Network Connections to get the latest driver for the IGB.
You can also go thru Intel® Ethernet Adapter Complete Driver Pack to get your driver updated to latest - if you haven't done so.
Kindly go thru the readme files for both driver as it will give you more insights.
Can you please confirm that you have the updated kernels?
Kindly get back to us with the errors if you have after all is updated.
Please let us know if you have any questions.
Thank you.
Hayat
IntelSupport
Community Manager
Hello raju1421,
Regarding your thread, we are following up to find out if you were able to complete the actions, we previously recommended.
Please reply to this thread to confirm, so we can continue helping with a resolution. Looking forward to receiving your reply!
Thank You
Hayat
Intel® Customer Support
raju1421
We are using the latest kernel and drivers. Please let us know how we can resolve the issue.
Thanks & Regards
Satrasala Raju
IntelSupport
Community Manager
Hello raju1421,
We have identified that the thread is related to FPGA development kits and falls outside the scope of our support.
We will proceed to transfer this thread to the appropriate group to ensure you receive better support accordingly.
Hayat
raju1421
Thanks for the response.
Please forward the thread to FPGA development kits because we need to close this query as soon as possible.
Thanks & Regards
Satrasala Raju
