6367 Discussions
Altera Cyclone V development board FPGA problem (error code:-4)
I am working on the Altera Cyclone V Development board (revision D).
It seems that the FPGA image is not loaded after power up. I found following lines in the uboot bootlog:
reading soc_system.rbf
7007184 bytes read in 2368 ms (2.8 MiB/s)
altera_load: Failed with error code -4
My board switch and jumper settings are listed as below:
SW1 All OFF
SW2 All OFF
SW3 1:ON 2:ON 3:ON 4:ON 5:ON 6:ON
SW4 1:OFF 2:OFF 3:ON 4:ON
J5 open
J6 shorted
J7 shorted
J9 open
J13 shorted
J16 open
J26 right shorted
J27 right shorted
J28 right shorted
J29 right shorted
J30 left shorted
J31 shorted
Please help
FBuss2
I had the same problem. The reason was the wrong setting in the "Convert Prorgamming File" tool. When you add the SOF file, select the file, then click on "Properties" bottom right. Then click on "Compression". This is how it looks like in Quartus Prime 18.1.:
You also need to set the "Mode" to "Passive Parallel x16". Then save the soc_system.rbf file to the FAT partition on the SD card and u-boot can load it.
TOoi
Thanks for the solution provided @FBuss2​ . Have been searching this error code for a while. I wish to add on something, the "Mode" is set according to the MSEL pin u set on the DE1-SoC board. You can refer to the table below, the table can be found in DE1-SoC User Manual provided by Terasic, section 3.1 Settings of FPGA Configuration Mode. table.PNG
