When I test the Altera Development Kits DK-DEV-10AX115S-A, I found some defective in J2. I connect the AD9265-FMC-125EBZ into J2, then I can't receiver the good response. Of course, I promise the AD9265-FMC-125EBZ is good. And when I change another DK-DEV-10AX115S-A, the result is good. So, I came to the conclusion that the original DK-DEV-10AX115S-A was bad. I measure the impedance of J2 with a multimeter, and I find D18(FMCB_LA_TX_N6) and G12(FMCB_LA_RX_P2) are about 30kohm to GND, they are difference with another good one
Hi lzhou5,
Please let me know are you looking for RMA request?
Thank You.
YL
Thank you very much for your response.
I am looking for RMA request several days. But without correct way.
S/N:10APCIe0003421
P/N:6XX-44366R-0G
I bought it from Mouser .
Hi lzhou5,
I believe this thread is the same as the thread available at link below. I will continue to support you on the thread at link below:
Thank You.
YL
