I am a newbie to FPGA design and implementation. While installing the PCI express board on LINUX machine, I don't see Demo application driver for DMA read and write for LINUX (Manual talks about windows installation). I want to generate DMA read and write in Linux box. Does anyone have pointer to a sample application, driver or sof file for the same. Let me know if I am wrong in understanding. Thanks in advance. -VineetLink Copied
- « Previous
- Next »
Any idea what might be causing this problem? I m using PCI compiler express in SOPC builder:
[ 4378.233120] BAR0 0xd0000000-0xd07fffff flags 0x0012120c [ 4378.233153] BAR2 0xff600000-0xff60ffff flags 0x00020200 [ 4378.233276] BAR[0] mapped at 0xf81c0000 with length 32768(/8388608). [ 4378.233373] BAR[2] mapped at 0xf8140000 with length 256(/65536). [ 4378.233447] bar_tests(). [ 4378.233466] write_header = 0xf8140000. [ 4378.233488] read_header = 0xf8140010. [ 4378.233511] &write_header->w3 = 0xf814000c [ 4378.233534] &read_header->w3 = 0xf814001c [ 4378.233556] ape->table_virt = 0xf65a4000. [ 4378.233608] Allocated cache-coherent DMA buffer (virtual address = 0xfffffffff6150000, bus address = 0x0000000036150000). [ 4378.233747] Filled First descriptor , read [ 4378.233773] Descriptor Table (Read, in Root Complex Memory,# = 1) [ 4378.233804] 0xf65a4000/0x00: 0x00000000 [ 4378.233829] 0xf65a4004/0x04: 0x00000000 [ 4378.233852] 0xf65a4008/0x08: 0x00000000 [ 4378.233875] 0xf65a400c/0x0c: 0x0000fade [ 4378.233900] 0xf65a4010/0x10: 0x00000800 [ 4378.233924] 0xf65a4014/0x14: 0x00001000 [ 4378.233947] 0xf65a4018/0x18: 0x00000000 [ 4378.233971] 0xf65a401c/0x1c: 0x36150000 [ 4378.233996] writing 0x00060001 to 0xf8140010 [ 4378.234023] writing 0x(null) to 0xf8140014 [ 4378.234049] writing 0x365a4000 to 0xf8140018 [ 4378.234069] Flush posted writes [ 4378.234088] [ 4378.234097] Start DMA read [ 4378.234119] writing 0x00000000 to 0xf814001c [ 4378.234141] EPLAST = 64222 [ 4378.234159] POLL FOR READ: [ 4378.234182] ape->table_virt->eplast (0xf65a400c) = 0x0000fade. [ 4378.234208] EPLAST = 64222, n = 0 [ 4378.234242] ape->table_virt->eplast (0xf65a400c) = 0x0000fade. [ 4378.234268] EPLAST = 64222, n = 0 [ 4378.234300] ape->table_virt->eplast (0xf65a400c) = 0x0000fade. [ 4378.234327] EPLAST = 64222, n = 0 . . < repeats> [ 4378.240440] Descriptor Table (Write, in Root Complex Memory,# = 1) [ 4378.240469] 0xf65a4000/0x00: 0x00000000 [ 4378.240495] 0xf65a4004/0x04: 0x00000000 [ 4378.240521] 0xf65a4008/0x08: 0x00000000 [ 4378.240546] 0xf65a400c/0x0c: 0x0000fade [ 4378.240570] 0xf65a4010/0x10: 0x00000800 [ 4378.240596] 0xf65a4014/0x14: 0x00001000 [ 4378.240621] 0xf65a4018/0x18: 0x00000000 [ 4378.240646] 0xf65a401c/0x1c: 0x36152000 [ 4378.240667] [ 4378.240676] Start DMA write [ 4378.240695] POLL FOR WRITE: [ 4378.240718] ape->table_virt->eplast (0xf65a400c) = 0x0000fade. [ 4378.240745] EPLAST = 64222, n = 0 [ 4378.240780] ape->table_virt->eplast (0xf65a400c) = 0x0000fade. [ 4378.240806] EPLAST = 64222, n = 0 . . . <repeats> [ 4378.246908] COMPARE: [ 4378.246933] [f6150000] = 0xf6150000 != [f6152000] = 0x00000000 ?! [ 4378.246956] DMA loop back (CPU->FPGA->CPU) FAILED [ 4378.246975] DMA loop back test FAILED.- Mark as New
Hi everyone.
I'm having a similar problem, gpushkar. I'm trying to run the DMA-test in a Arria GX II, but somehow the FPGA is not updating the EPLAST register, which means the DMA is not going at all through the Descriptors! I wonder if it is a matter of wrong addressing... Did anyone manage to get more insight into this? Best regards, Pedro
- « Previous
- Next »
