When powered on the Altera cyclone v FPGA board, the general seven segment display and LED are not blinking. Before this it was displaying. When i check the power adopter, it shows 12.5v. What may be issues, please reply.
Good day
Thank you for using Intel Premier Support. I'm Elina looking into your issue and allow me some time to look into your issue. I shall come back to you with findings.
Thank you for your patience.
Elina
Thanks for the response. Device is 5CGXFC5C6F27C7. When powering on D5 led only is glowing, which is an indication of 12v. But other normal displaying of board like segment display and rest led are in OFF condition. Waiting for your reply on this issue.
Hi
Good Day,
You may try reset the board to check first. Thanks
Best Regards
Elina
Hi
Pressing the reset button has no effect on the board. Same as before.
I have not received any further solution yet. Please reply.
Hi
Good Day,
Thank you for the information that were provided to us last time. Apologies for late response due to weekend day. Below here are the suggestions to debug your devkit Led issue:
1)Do you have another cyclone V device ? can you try to connect it with the host/workstation/server and see if you still seeing the same issue ?
2) You may try change into new jumper wires.
3) Reprogram the .sof file.
Elina
the board can be identified as Terasic Cyclone V GX starter kit.
You either deleted/replaced the factory configuration or - in the worse case - managed to damage the board.
Did you try the "Restore Factory Configuration" procedure described in user manual?
Thanks for your valuable suggestion.
After opening the jumper and closing the jumper in jp15 and jp16 position again, now the normal displaying is occuring (LED and seven segment dispalying) and board is also programming, however there are some issue arises. Power is off to the board but the D5 led indication of 12v is blinking suddenly and then disappears , this occurs in repeated manner. Second thing, in my developed system, i am setting some default setup for the leds through push button switch for data acquistion from another board. That was working fine. But now that default set up of LED position is not remaining stable, after setting it should capture data, but that default setting is changing automatically, so i am not able to collect data. Third when FPGA board is connected to another board, current fluctuation is occurring in power supply that is connected with the FPGA. Please reply as soon as possible, as I am not able to do my work. I have got this single board now, no new board with me now. Waiting for reply.
Pratap
LED blinking is stopped now, after connecting to a new external power source. But the rest two problem remains. In my developed system, i am setting some default setup for the leds through KEY button for data acquistion from another board. That was working fine. But now that default set up of LED position is not remaining stable, after setting it should capture data, but that default setting is changing automatically, so i am not able to collect data. Also, when FPGA board is connected to data acquisition board, current fluctuation is occurring in power supply that is connected with data acquisition board. please suggest on this.
Hello PK16,
I would like to inquire if your issue has been resolved. I apologize for the delay in responding to your comment as I was on leave.
Elina
