I've been following the tutorial (BeMicro_SDK_Embedded_System_SW_Lab_v1_21.pdf) to flash the factory default image into the BeMicroSDK stick. On the console everything seems expected. After completion the button "RCFG" is pressed according to the tutorial. But after that nothing happened on the stick. All 8 LEDs went orange as it was inserted into the PC. It should have displayed the temperature in a coded format, in green. Wondered if there are something more needed to be done, or if my stick got some problem? Thanks in advance.Link Copied
