5924 Discussions
Anybody experienced a failure on power-up of the stratix IV gx devkit?
VBart
Devkit is DK-DEV-4SGX230N.
I powered it with 18.75VDC, 3.15A, center-positive powersupply on DC input J4. Here is the damage done to the board (C96 burned). Note that C95 is not burned.
Location of C96 in schematic :
This is the only component that burned on the board. Even C906 is not burned.
AR_A_Intel
Hello
Welcome to INTEL forum. You are using 18.75VDC, 3.15A, center-positive power supply. May I know, is this power supply that comes together with Dev kit board? Could you attach picture of the power supply/adapter that you use.
VBart
Hi
The devkit did not come with a power supply. Here is powersupply that i use :
thanks
AR_A_Intel
Hi
Based on my understanding, the Stratix IV GX FPGA Development Kits should contain Power adapter and cables. Refer here https://www.intel.com/content/www/us/en/programmable/products/boards_and_kits/dev-kits/altera/kit-siv-gx.html#Top
Using other than authorized power adapter that comes together with Dev kit board will result not entitled for warranty claim as we are unsure about the quality of another brand power adapter.
