Apply RMA from Altera
BWU15
last time we send 3pcs samples to your side for FA, The FA# is   CISCO-F005 . As this is fabrication defect found in the samples ,so can you provide the CN for scarp the 3pcs in your side ? By the way ,can we return the defects to you side when the components has the” GET_ROMMON” failure in the further ?We believe it is helpful for you to investigate, thanks!
Zawani_M_Intel
Hi BWU15,
Could you please provide the total unit failed vs total units has been used?
Thanks!
Wani
BWU15
Hi WaniMY,
You mean the defects on our side and the usage for it ?Can we return to your side from your website regularly? Thanks !
Zawani_M_Intel
Yes, the total defect units and the total unit that you used.
We need to investigate on the lot history for your case. Please allow me some time to get some details on the requirement.
Thanks!
Wani
Zawani_M_Intel
As there are no more further query, I believed the case has been resolved.
Have a great day!
Wani
