We have an Arria 10 Development Board (10AX115S-A) that has encountered a failure, and there is a noticeable burnt smell coming from a specific area (please see the attached image). Is it possible to repair this board? If so, what are the available options for repair or replacement?
Thank you for your assistance.
looks like a cracked input capacitor. If I decode the component identifier correctly, it's a 100 uF tantal capacitor at the 12V input jack. I guess it was damaged when plugging in the powered connector, tantal capacitors don't stand inrush currents so well.
If one of the DC_INPUT capcitors is shorted and there are no other damages on the board, it can still work when supplying it through ATX connector or PCIe. I'd replace the defective capacitor with SMD tweezer solder tool.
Hi Tora,
We sincerely apologize for the inconvenience caused by the delay in addressing your Forum queries. Due to an unexpected back-end issue in our system, your Forum cases, along with others, did not get through as intended. As a result, we have a backlog of cases that we are currently working through one by one.
Please be assured that we are doing everything we can to resolve this issue as quickly as possible. However, this process will take some time, and we kindly ask for your patience and understanding during this period. The cases will be attended by AE shortly.
We appreciate your patience and understanding, and we are committed to providing you with the best support possible.
