I am using a Arria 10 GX development kit that will reset after reaching a chip temperature between 40C and 43C reverting back to the state it was in on power on and before I programmed it. Even when running the board test system with the fan running on fast the board will reset.
Hi mtbarnard (http://www.alteraforum.com/forum/member.php?u=93923)
I'm facing the exact same problem. Did you find a solution? Cheers, Stoffe- Mark as New
I returned mine to Altera after submitting a service request. The cause may have been overheating as some of the Arria 10 dev kits were shipped without thermal paste.
