6367 Discussions
Arria 10 SOC Booting flow and commands for Quartus 20.1 std
sukesh
I am working on Arria 10 SOC Eval Kit and doc Arria 10 SoC GSRD | Documentation | RocketBoards.org helped me run an example hello world and toggle the LEDs on the Board through commands listed in the Doc.
Further I am looking forward to work on my custom code a. But I am finding difficulties to pull a right booting procedure document for Quartus version I am currently working. Kindly help me by providing a firm document which targets specific version mentioned below.
Note:
Quartus Version: 20.1 std
SOC EDS: 20.1 std
Ubuntu: 20.4
Sukesh.Pednekar
sstrell
What document are you looking for?  The link you provided has boot flow information.
sukesh
The link I provided mentions the perquisites as:
  • Intel Quartus Prime Pro Edition v21.3 (v23.3 for rebuilding the current monthly GSRD release)
Whereas I am looking for the boot flow information on Quartus prime std 20.1 version. Also, the doc does not cover on how to work on custom files to generate the bootloader and SD Card image.
Sukesh.Pednekar
mabdrahi
Hi Sukesh,
I will check your request on firm document which targets specific version mentioned above"
as i dont have instant answer for that yet.
Thank you,
Aliff
sstrell
The Quartus version won't really matter.  The flow for Arria 10 hasn't changed in years.
mabdrahi
Hi Sukesh,
The step from Arria 10 SoC GSRD | Documentation | RocketBoards.org is compatible to your version.
do you have customize your design and software?
If yes, do you have problem any problem in your project?
if yes, do you have any error log?
Thank you,
Aliff
mabdrahi
Hello Sukesh,
Any update from you?
Thank you,
Aliff
mabdrahi
Hi Sukesh,
Since I had provided you the solution and did not receive any feedback from you . Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
If you think you would rank your support experience less than 4 out of 5, please allow me to correct it before closing or if the problem can’t be corrected, please let me know the cause so that I may improve your future service experience.
Thank you,
Aliff
