5784 Discussions
Arria 10 SoC - Boot from SD Card
fpga_2022
hi,@EBERLAZARE_I_Intel,i do run "make generate_from_tcl" first。
i want to reply you, but,the reply button is not work。
EBERLAZARE_I_Intel
Can you share your full design and I try them from my side?
EBERLAZARE_I_Intel
If you still having issue with the reply button, can you attached the design in email along with this link, to my email: eber.lazareen.ignatius@intel.com
We may proceed with the communication there.
EBERLAZARE_I_Intel
Update:
Case is solved via email:
Unfortunately above commands are not supported to be executed in WSL, only in Linux, you can install a Virtual Machine, and do the commands.
  • How to convert sof to rbf:
https://www.intel.com/content/www/us/en/docs/programmable/683536/current/converting-the-programming-file.html
You can follow the split rbf steps above.
  • When running "tools/mkimage -E -f board/altera/arria10-socdk/fit_spl_fpga.its fit_spl_fpga.itb" I get "sh: 1: dtc: not found"
To solve:
sudo apt-get install device-tree-compiler
