5780 Discussions
Arria 10 Soc Development Kit shows no text on the display.
KBred1
I start with the "Quick Start Guide - Verify Basic Operation". I see no text on the display and the red LED D17 flash configuration fails is on.
On the UART J10 I see:
U-Boot 2014.10 (May 01 2016 - 08:22:23)
CPU  : Altera SOCFPGA Arria 10 Platform
BOARD : Altera SOCFPGA Arria 10 Dev Kit
DRAM: WARNING: Caches not enabled
SOCFPGA DWMMC: 0
FPGA: writing socfpga.rbf
FPGA: Poll CD failed with error code -10
INFO : Skip relocation as SDRAM is non secure memory
Reserving 2048 Bytes for IRQ stack at: ffe2db10
data abort
pc : [<ffe00b1a>]         lr : [<ffe01d4d>]
sp : ffe3bf00 ip : 0000001c    fp : 00000001
r10: ffd02078 r9 : ffe3bf60    r8 : ffe00054
r7 : ffe20b60 r6 : ffe3c000    r5 : 00000000 r4 : ffffd000
r3 : ffcfb000 r2 : 00000002    r1 : 00000001 r0 : 00000001
Flags: nzcv IRQs off FIQs off Mode SVC_32
Resetting CPU ...
resetting ...
Our DHCP Server is running. But I can't ping the board. We put the mac adress in the Server what I found with the BoardTestSystem.exe.
What else can I do to get the board up?
EBERLAZARE_I_Intel
Hi, here is a link for you to refer to try and boot from SD card image and use it to boot Linux on the Altera Arria 10 SoC Development board:
https://rocketboards.org/foswiki/Documentation/A10SGMIIRDBootLinuxFromSDCardLTS
Prior to that, to create the SD Card image please refer to the link:
https://rocketboards.org/foswiki/Documentation/A10GSRDCreatingAndUpdatingTheSDCardLTS
Let me know if you encounter any problems.
KBred1
Hi, now the board starts with the QSPI_TPBGA Card instead of the sd card. It gets an IP from the DHCP Server. I have to put in U-Boot the mac adress with setenv. Or I can start the board with the NANDX8 card. But here I can't use setenv so I don't get an IP from the DHCP Server. When I start the board with the QSPI-TPBGA card successfully I can't use "Interaction with" in the webserver because I can't see the pticture with the board where I can do something. I tested it with Firefox and Internet Explorer on windows 10.
EBERLAZARE_I_Intel
May I know the specs for both the QSPI_TPBGA and the SD card?
There might be a compatible issue with the SD card that leads to the board starting with the QSPI_TPBGA Card instead of the SD card, we recommend that you use the flash devices that is Known-to-Work with the Arria 10 SoC;
https://www.intel.com/content/www/us/en/programmable/support/support-resources/supported-flash-devices-for-arria-10-soc.html
If the QSPI_TPBGA is Known-to-Work, then please verify the steps to boot the Arria 10 board using QSPI:
https://rocketboards.org/foswiki/Documentation/A10GsrdQspiBootLTS
But, if you want to boot the board with the NAND card, its fine too, here is the link that could help you;
https://rocketboards.org/foswiki/Documentation/A10GsrdNandBootLTS
Prior to that you still need to check if the NAND device is compatible with the Arria 10 SoC via the first link.
If you can share the specification of your cards and that it is Known-to-Work with the Arria 10 SoC, I can check if there is an Example Design that could help you.
KBred1
I use the cards witch comes with the Arria 10 SoC Development Kit. I have to plug off the SD card modul with the s/N P/N 17050039-0311 from J23 und plug instead the QSPI-TPBGA modul S/N 6xx-44334R-0A P/N 17050037-0297. Maybe the sd card is broken. I will get a new one. Where I can find an image for my SD card modul?
Kai
