5692 Discussions
Arria 10 : Uboot Configuartion Settings
PJais1
I am building linux OS for our custom board which took reference from Arria 10 SoC .
I build u-boot image by taking reference from https://rocketboards.org/foswiki/Documentation/A10GSRDGeneratingUBootAndUBootDeviceTree
and boot from SD card https://rocketboards.org/foswiki/Documentation/A10GSRDCreatingAndUpdatingTheSDCardLTS
But the uboot is not booting when board is powered on.
As I am using custom board, i did changes in qsys file in quartus tool and generated .sof file according to our pin muxing at HPS side.
I am having a doubt that while generating uboot.mkpimage.img do we need to make changes in uboot-socfpga folder ? and if so, where do i modify these changes?
Priya
EBERLAZARE_I_Intel
Did you replace the DDR module? If yes may I know the data sheet for the DDR that you are using?
Which quartus version or you using? Can you share the uboot log?
EBERLAZARE_I_Intel
After getting the new generated sof files, the handoff folder will be generated as well according to the new compilation.
Thus, a new uboot img need to be made again by the "make uboot" command in SoC EDS based on the new generated handoff folder.
I hope this is clear.
PJais1
Thanks for the help. I did the same earlier too. Actually, there was problem in DDR timing parameters , I have updated them in quartus tool, using DDR3 datasheet, and now uboot is sucsessfully build.
EBERLAZARE_I_Intel
Thanks for the update and I apologize for any delay in my responses.
Let me know if more help needed.
