5925 Discussions
Arria 10 : data abort after DDR calibration
PJais1
I am designing Linux OS for our custom board based on Arria 10 SoC.I have build uboot and peripheral rbf image and uploaded them in SD card.In our custom board we have used DDR3 memory at HPS side.
While booting, the console is showing a data abort and prefetch error after DDR calibration:
U-Boot 2014.10 (Sep 19 2019 - 11:13:27)
CPU  : Altera SOCFPGA Arria 10 Platform
BOARD : Altera SOCFPGA Arria 10 Dev Kit
I2C:  ready
DRAM: WARNING: Caches not enabled
FPGA: writing ghrd_10as066n2.periph.rbf..
FPGA: Early Release Succeeded.
SF: Detected N25Q1024A with page size 256 Bytes, erase size 4 KiB, total 128 MiB
DDRCAL: Success
INFO : Skip relocation as SDRAM is non secure memory
Reserving 2048 Bytes for IRQ stack at: ffe3a6e8
DRAM : 2 GiB
Wdata abort
prefetch aààort
Could anyone please suggest how to remove this error?
Priya
EBERLAZARE_I_Intel
Just to check, when using the DDR4 memory, were you able to boot the Arria 10 successfully?
Are you using the design from our GHRD?
Regards.
PJais1
I haven't designed using DDR4 as in our custom design DDR3 is connected at HPS side. Also , I am using the design from example design in SOC EDS embedded folder .
EBERLAZARE_I_Intel
I've noticed you are using Early IO release feature. This means there should be two .rbf files needed, peripheral and core.
EBERLAZARE_I_Intel
PJais1
Hello ,
I have followed the same manual for early release IO and created peripheral and core rbf and specified peripheral in bsp-editor. In the sd card , i have loaded both core and peripheral rbf.
Also, I have tried full configuration feature, where i loaded a single rbf and removed early IO feature.The uboot hangs after DDR calibration.
As I searched in the uboot source code, the misc.c file in arch/arm/cpu/armv7/socfpga_arria10 , the code hangs at below line in the skip_relocation() function:
/* assign the global data to new location, no longer in stack */
gd = id;
/* rebase the stack pointer as we won’t jump back here */
asm volatile (“mov sp, %0” : : “r” (gd->start_addr_sp)
: “r0”, “r1”, “r2”, “r3”, “ip”, “lr”, “memory”, “cc”);
Could you please help with above issue?
R_
I am also getting same error.Did you solve the issue.
R_
Can provide some inputs regarding this?
PJais1
As we have replaced DDR4 with DDR3 , we have updated all the timing parameters, using the datasheet of MT41K512M16HA-107(DDR3) in our memory timing i/o in quartus tool and successfully booted U-boot.
If you are having same data abort error after callibration, check all the timing and speed parameters according to the DDR which you have used.
R_
We have 2GB DDR4 memory with ECC enabled and some of the boot times we are getting below error
U-Boot 2014.10 (Sep 25 2019 - 16:32:41)
I2C:  ready
SOCFPGA DWMMC: 0
FPGA: writing ghrd_10as066n2.periph.rbf ...
DDRCAL: Success
SDRAM: Initializing ECC 0x00000000 - 0x80000000
SDRAM-ECC: Initialized success with 2148 ms
Reserving 2048 Bytes for IRQ stack at: ffe386e8
DRAM : 2 GiB
Error: DRAM address mismatch error occurred
decoder0: erraddr = 7fefefc0
decoder1: erraddr = 7fefefc0
decoder2: erraddr = 7fefefc0
decoder3: erraddr = 7fefefc0
### ERROR ### Please RESET the board ###
Error: DRAM ECC DBE occurred
erraddr = 7fefefe0
Info: DRAM ECC SBE @ 0x7fefefc0
Info: DRAM ECC AUTO CORRECTION SBE ADDRESS @ 0x7fefefc0
When i check source code of uboot it is failing with below line
Do you have any idea?
Jay_Foresys
R_
Did you determine the cause/resolution of the error:  Error: DRAM ECC DBE occurred ?
PJais1
In our design we did not had ECC enabled . You might check the design parameters in the quartus tool for the DDR used.
