Arria 10 hold violations
IanD
Using an Arria 10 board. Setup timing is clean, but I'm getting a few hold violations from the Arria PHY to an input FIFO. Clocks are correct and the violation only shows up sometimes. I.E - when signaltap is used.
Any ideas on how I can fix these? Is there a post-route option or pre-route constraint?
RichardTanSY_Intel
Do you mean the hold violation occur sometimes? Do you get it to pass timing before?
If so, it might be marginal issue. Try to run seed sweep to get the best fit that close timing.
Do you have enough positive slack for setup? You can set "All paths" in the "Optimize Hold Timing" in the Advanced Fitter setting in the Compiler Setting.
Richard Tan
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 4/5 survey.
IanD
Thanks Richard. This only happens sometimes. The problem flop-flop paths have plenty of setup, but other paths on the same clock are just meeting setup.
I do have the "Optimize Hold timing" set, but I would like to try the seed sweep when I next see the problem. I don't see this option in version 21.3. Where can I find it?
RichardTanSY_Intel
You may checkout this video on how to run seed sweep.
https://www.youtube.com/watch?v=1cc74E3zaeI
Richard Tan
RichardTanSY_Intel
Hi, do you need further help in regards to this case?
Richard Tan
RichardTanSY_Intel
As we do not receive any response from you on the previous question/reply/answer that we have provided. I now transition this thread to community support.
Richard Tan
