5930 Discussions
Arria II GX Dev Kit - Ethernet RGMII
Hi
I am new to FPGA world and thanks for the time.
I am trying to run following reference design in lookback mode.
http://www.alterawiki.com/wiki/triple_speed_ethernet_with_rgmii_interface_hardware_test_by_using_system_console_reference_design
Some how what ever I do I am not able to see any packets transmitted. I feel I am making very silly mistake.
If I load default Web-Server I can see Tx LED flashing indicating packet transmission. So there is no hardware issues.
Thanks for the help in advance.
Load the sample project and copy tse_my_system.c file to Your project.
I am using Quartus 10 sp1.
I found the issue. There is a clock shift for Tx_clk and Rx_Clk in PHY.
I changed the Clock to 90 degree shift and every thing is working fine.
Thanks for the help.
