5779 Discussions
Arria10 Transceiver PHY basic design with 10GBase-R protocol example
druva1
Does anyone have a simple example Arria10 Transceiver PHY basic design with the 10GBase-R protocol?
I have already managed to simulate the Arria10 Transceiver PHY with a basic(standard PCS) protocol.
I set up a single Channel and pass a simple counter (pattern generator) from the tx to the rx (8 bits)
But I want to use now the 10GBase-R protocol and I cannot find a simple example. Any tips are welcome.
Cheers
Deshi_Intel
HI,
FYI... Intel is already offering few Ethernet 10G IP solution directly with below example design link.
You can check it out instead of building your own Ethernet design solution
dlim
