5922 Discussions
Arria10SOC Dev Kit Board: Updating EPCQL1024 show “209012 Operation Failed”
JET60200
We have 2pieces of Arria-10-SOC-development-kit board from Intel.
​WE tried to update the on-board EPCQL1024 flash.The detailed steps as following:
1) Switch On board's “SW4 Bit-3" as High "1", that will config FPGA as AS Mode;
2) convert *.sof to *.jic format file, Then use JTAG to burn .jic
Problem is : always we saw ERROR :
" 209012 Operation Failed ", never succeed to work out.
Does anyone have experience with updating the EPCQL1024 flash via JTAG on Arria10SOc board ? thanks in advance !!
JET60200
attached is my Quartus Console showing this ERROR - " 209012 Operation Failed " , Hope helps urgently.
ShafiqY_Intel
Hi 3000021845821.562225903895492E12 ,
Can you kindly try to reduce your TCK frequency to 6 MHz?
Below link is the command to change TCK frequency (on page 14= 2.8. Changing the TCK Frequency)
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_usb_blstr_ii_cable.pdf#page=14
Kindly try it out with your design and let me know the result.
DamBam
Hi @JET60200,
I came across the same issue, and the fix turned out to be bypass MAXV IO Mux from JTAG chain (by switching SW3.2 to UP position)
JET60200
Hi  @DamBam
Thanks for update us with your results,  Appreciate it  //
