We have 2pieces of Arria-10-SOC-development-kit board from Intel.
WE tried to update the on-board EPCQL1024 flash.The detailed steps as following:
1) Switch On board's “SW4 Bit-3" as High "1", that will config FPGA as AS Mode;
2) convert *.sof to *.jic format file, Then use JTAG to burn .jic
Problem is : always we saw ERROR :
" 209012 Operation Failed ", never succeed to work out.
Does anyone have experience with updating the EPCQL1024 flash via JTAG on Arria10SOc board ? thanks in advance !!
Hi 3000021845821.562225903895492E12 ,
Can you kindly try to reduce your TCK frequency to 6 MHz?
Below link is the command to change TCK frequency (on page 14= 2.8. Changing the TCK Frequency)
Kindly try it out with your design and let me know the result.
Hi @JET60200,
I came across the same issue, and the fix turned out to be bypass MAXV IO Mux from JTAG chain (by switching SW3.2 to UP position)
Hi @DamBam ,
Thanks for update us with your results, Appreciate it //
