Community
cancel
Showing results for
Search instead for
Did you mean:
Honored Contributor I
Assistance with code for C5G Dev kit: Converting code
Hello all,
First off, I'm very new when it comes to working with FPGAs. I've looked through the tutorial and have a basic idea what I'm doing at least.
I've very recently purchased the C5G dev kit and the SFP-HSMC provided by Terasic as my team and I are building an optical comm system to help test our system here in my optics lab - we figured an FPGA would be a fairly cheap and powerful solution to what we need. I was looking around and found an example code for the cyclone 5 here on the wiki:
http://www.alterawiki.com/wiki/file:cvgx_devkit_seriallite_4_lanes_2500mbps_megacore.zip
This code basically does everything we had hoped this system could do; however, the code was written for the chip: 5CGXFC7D6F31C7ES. The chip on the C5G (5CGXFC5C6F27C7N) does not appear to be immediately compatible with this code.
My question for you all, can I simply reassign the pin planning for this code to work with the C5G, or is there some other steps I need to do to convert the code over? Again, I'm a beginner when it comes to FPGAs and would really appreciate some assistance in working with these devices a bit.
Without looking at the project, since it targets Cyclone V, all you would have to do is adjust the pin assignments.
