5924 Discussions
Avalon st single clock fifo
srinivasan
I am using Avalon st single clock FIFO...In that how to give CSR data and address.
Otherwise can anyone share the reference design using CSR in Avalon FIFO...
sstrell
The Embedded Peripherals IP user guide has details on the registers:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_embedded_ip.pdf
Nurina
Hi Srinivasan,
Did the above reply address your problem? Do you have more questions?
Nurina
PS: If you find any comment from the community or Intel Support to be helpful, feel free to give Kudos.
srinivasan
Thanks for your reply,
Already that pdf only I am following,but I want about CSR address means which register value need to assign in that signals..
I don't know what input need to give for that IP..
Can you please share the testbench for that IP or any design or simulation result...
srinivasan
can u please share the CSR registers configuration document details....
Nurina
You can find that information on Table 10 on page 35 of the document sent above.
This design example might help: https://fpgacloud.intel.com/devstore/platform/17.1.0/Pro/rapidio-ii-reference-design-for-avalon-st-pass-through-interface/
Nurina
srinivasan
Can you please share the quartus project design file for Avalon st single clock fifo using CSR interface with testbench...
Because I am struggling in giving the CSR address and CSR write data for getting almost empty and almost fill signal...
Can anyone please help me on this
Nurina
Unfortunately we don't have what you want from our example design catalog. Perhaps generating a testbench on Platform Designer could help?
You can also watch this video for reference, it gives detailed explanation on how you can use Avalon-ST.
Let me know if this helps.
Nurina
srinivasan
   I didnt receive any video link,can you please share it again..
Nurina
Nurina
We did not receive any response to the previous question/reply/answer that I have provided, thus I will put this case to close pending. Please post a response in the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
Nurina
