According to datasheet, when USE_TERMINATION_CONTROL set to TURE. It will be able to use seriesterminationcontrol and seriesterminationcontrol_b to change the serial termination on Cyclone 10 LP device.
My question is how to convert the termination value to match the seriesterminationcontrol?
To assign an OCT termination to an LVDS input pin,Can you use the setting as below
set_instance_assignment -name INPUT_TERMINATION DIFFERENTIAL "OCT 100 OHMS" -to <pin Name>
Thank you ,
Sree
