Can I do BareMetal Application for Stratix-10 H-Tile EVM board.
If possible please share the procedure to do BareMetal on stratix-10 H-Tile EVM.
Thanks in advance.
Hi, Tiru,
let me check and let you know EOD
Hi Raju,
May i know where is your reference for this board?
link, document or any picture
Hi Tiru,
Can you share to me information about the board? (datasheet)
so I can know better about the board
Hi Tiru,
After discussion form our internal team, the Stratix 10 devkit and EVM can use same baremetal application. Here is the example we can refer https://www.rocketboards.org/foswiki/Documentation/HWLib
In this example, there can only compile by using ARM DS. I have try other crosscompiler GCC or GNU but its not working for CLANG baremetal compilation.
Hi Tiru,
Apologize for being late.
To build the S10 baremetal, I only have this reference. https://github.com/altera-opensource/intel-socfpga-hwlib/tree/master/examples/S10/Altera-SoCFPGA-HelloWorld-Baremetal-S10-ARMClang.
you can port other baremetal application base on your desire.
You need ARM DS software to compile, run and debug the baremetal application.
you can get the ARM DS from here https://fpgasoftware.intel.com/armds/. Current version is 2020.1. The filename is DS000-BN-00000-r20p1-00rel1.zip..
you also might need license. you can get from https://developer.arm.com/support/licensing.
As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support.
