5283 Discussions
BeMicro SDK - is there any way to...
.. remove the plastic cover from the stick?:D
Yes I know it is kind of strange question but I do appreciate any input. Thanks in advance.
yes, the case snaps off. you can also reattach it
Great thanks!
Hmm does it come of in one piece or will it split into two?
I looked and looked but couldn't find any opening in the transparent cover, but there is obviously a slit somewhere along the base (from which i suspect it can be opened into two). It locked pretty tight with the baseboard :confused:
its two pieces, the "floor" of the shell comes out and you can pull the board out from the bottom
Many thanks! Just opened it by inserting a flat screwdriver from the USB side at the floor slit, and like what you said the floor came off, and the rest can be removed pretty easily.
Thanks again!
