I am a software developer and I'm investigating the potential of using NIOS II with MicroC/OS-II for my application. I am able to execute the tutorial until I get to 4.2 when I get the system id mismatch - connected: "0x6060d7d5", expected: "0x0". Hitting the (REFRESH CONNECTIONS) button does not correct the issue. The System ID Properties is included below: expected system id base address: 0x80002a8expected system id: 0x0
connected system id: 0x6060d7d5
expected system time stamp: 1313716022
connected system time stamp: 1287701530
I'm running Quartus 11.1 with NIOS II EDS from the Altera website. Any help here would be appreciated. Thanks! John
I am having the same problem. Can anybody comment?
I think it has something to do with the EPCS chip. Any thoughts?
I've the same problem.
Does this simply mean that the nios system in our fpga is different from the one used in the lab material? Can flashing the image from the lab material solve the issue? This is my first hands on fpga, must investigate before doing things- Mark as New
It works!
Just follow Appendix A instructions to restore the factory image of the lab materials: In the Nios2 Command shell, go to the Factory_Image directory and type source restore_factory_image.sh
Topic Options
