BeMicro - Work Shop
1. Can I buy this USB port based dev kit ?
2. Price and availability ?
3. Are there any limitations on the tools bundled with this USB based dev kit ?
GKM
1 - Yes
2 - Talk to your Arrow or Altera rep
3 - No tools come with the dev. kit. You download the free web edition of the Quartus software. You get no IP licenses.
1. Thanks for the quick reply.
2. You get no IP licenses.
Dos this mean that I can develop special functions say a correlator, modulator, NCO etc and use them .
Modules OR Libraries made by ALTERA - which are priced can not be used ?
Please clarify.
GKM
Altera let's you evaluate their IP cores without licensing them. They use what is called OpenCore Evaluation. The IP core will compile and run in the part but here are the restrictions:
1 - Quartus will only produce a time-limited SOF file. It will not produce any type of file that you can use to program a flash device. You'll only be able to program the FPGA via JTAG.
2 - When running the design with the time-limited SOF, you must either
a - Leave the JTAG cable connected while the design is running
b - Disconnect the JTAG cable in which case the IP core you are evaluating will stop working after 1 hour.
You can of course use your own IP all day long without any consequence. Anything you develop is yours and does not require a license.
Jake
GKM
