6104 Discussions
BeMicroSDK Nichestack Timer
The Qsys and or SOPC files for the BeMicro downloaded from various sources (example code from Microtronix and altera wiki superloop) have the high resolution timer set to 1us (processor running at 100MHz).
Surely some mistake?
That high-res-timer is used only for performance tests (e.g. bandwidth tests). The only required clock is system clock.
Thank you kindly.
