6418 Discussions
Bemicro kit - embedded lab issues
I am getting down to the end of the embedded lab exercise.
It looks like there is documentation conflict with what the lab says and what I see on the NIOS Eclipse software. Additionally, I get an error message when I try to run the program.
Specifically, Page 42 of the bemicro Embedded System Lab says to build the bemicro_led_control_bsp and then the bemicro_Led_control project.
Page 43 then says to right click the software project directory(bemicro_led_control?), select RUN AS, Then NIOS II Hardware
(but this option is not presented
Instead, RUN AS gives you these options:
Local C/C++ program
Run Configurations
If you select Local C/C++ program you get the following error:
Launching bemicro_led_control.elf has encountered a problem
Error starting process
Clicking details, you get the following:
Details
Error starting process.
Cannot run program "C:\altera\bemicro\bemicro_sopc_builder_lab\software\bemicro_led_control\bemicro_led_control.elf": Launching failed
If you select Run Configurations, you get these options:
C/C++ Application - bemicro_led_control.elf
Launch Group
Nios II Hardware
Nios II ModelSim
If you select Nios II Hardware, then RUN, nothing happens.
If you double click Nios II Hardware, you get
Plug-in com.altera.sbtgui.launch was unable to load class com.altera.sbtgui.launch.hardware.us.Nios2HardwareLaunchConfigurationTabGroup
An error occurred while automatically activating bundle com.altera.sbtgui.launch(249)
Any help troubleshooting is appreciated.
Have you gotten past this out yet? What version of Quartus are you running? Is it the BeMicro or BeMicro SDK? If SDK, I'll try to run it if you post the .elf file.
I'm using the latest Quartus web edition 11.0 (downloaded a week or so ago) . I am using BeMicro, not the BeMicro SDK unfortunately. This appears to be a challenging process. Probably I will start from scratch again and see what happens....don't know what else to do.
I am having the same issue. I'm using NEOS II 11.1 SP2 on windows xp 32 bit. I cannot get it to run on the hardware using the bemicro fpga. I have followed the instructions presented exactly. Has this been resolved?
Yes, I did get it working.
There is hope for you!
However, it was awhile ago. I think I made some notes on it...I will post an update later.
But I think all I did is reinstall everything. The first time around everything is so new and you are trying to understand everything and get up and running (fast), it's very easy to miss something.
-Kevin
Hi, kdf5036
O.K, I found 2 (cryptic) notes I made back in December which is the last time I fired up the kit.
# 1 You have to exit Nios II system after a rebuild before you see RUN AS , NIOS
# 2. I got this message:
Target Connection]: System timestamp mismatch - connected: "1321331565", expected: "1322117462".
And then I couldn't run the program until I disabled the Timestamp check in the debug dialog window.
I'll see if there is anything else.....but now that I see my notes, I do recall that exiting and restarting the Nios II s/w seemed to solve the problem.
