Hi ;
Does anyone try the referece designs in the bitec website ? I woulf like to know if these examples are really working. thank youLink Copied
I'm looking to execute the pass through using HSMC Bitec DVI card. I put in my design the clocked video input connected to the clocked video output , but I didn't have any result.
Please can someone help me in this problem. Rabia- Mark as New
HI,
I have the same problem.NOne of the designs are working with bitec.I have reference design from the bitec website. I am using the design DVI_1080P_Loop_through_C120_Beta but it has many problems.- Mark as New
i never got the Bitec DVI input port to work with their designs or my own
I'm not sure which ref desgin you guys are talking about, but...
I used the HSMC to Displayport card. I tried the output side, but it was working fine. I've tried on the A2GX and S4GX as well. and both working fine with me.- Mark as New
I am trying the design with the design with Cyclone III ...The one with Arria and other are working.I have tried them too.But the cyclone 3 design has problem..- Mark as New
--- Quote Start --- I'm looking to execute the pass through using HSMC Bitec DVI card. I put in my design the clocked video input connected to the clocked video output , but I didn't have any result. Please can someone help me in this problem. Rabia --- Quote End --- I am trying the same thing as you..The cyclone 3 example has a stupid mistake which I discovered today.It doesnot have the constraints file added from to it for CVI and CVO... The path to add them is: add the altera .v files. C:\altera\10.0sp1\ip\altera\clocked_video_input\src_hdl and also the sdc constraints file which is in the link C:\altera\10.0sp1\ip\altera\clocked_video_input Add for both CVI and CVO.. For more reference look the design http://www.bitec.ltd.uk/dvi_loopthrough_1080p_civ.pdf It is same deign but just with cyclone IV. Alteast the design synthesis successfully.U can add the files which are added in this design to the eg of cyclone 3 design and it works.. I prefer to create my own design, similar to the example but more logical.If it doesnot work I can upload it here in future. Hope it helps..
so you did get the CIII loopback design to work in hardware?
I got it compiled and synthesized and fitted n everything.I am going to try it in the Hardware this week or may b next.I will post it if I get it working (which I have to anyways and at any cost). Sn- Mark as New
I got the code working on the DVI board Cyclone 3.The pre compiled code J8.sof can be successfully downloaded but when if I compile and synthesize the code on my own I have some errors but the precompiled code from bitec is working fine. If anyone needs help let me know!! Sn
Topic Options
