Board Extension for DE1-SoC
I'm looking for a solution how to connect to make "available" the DE1-SoC board for sensor boards with limited number of contacts, e.g. from here:
http://store.digilentinc.com/pmod-expansion-modules/pmod-boards/
On DE1-SoC there are two 40-pins headers (please see the snapshot below).
It would be nice to have some extension board that wires one (or better two) 40-pins header(s) to several standard headers (e.g. Pmod from Digilent, that have 6 or 12 pins).
Is someone aware of such extension boards ?
Thanks in advance.
Pavel
If nothing better comes along, you can just take a 40-pin IDE ribbon cable and solder as many breakout headers as you care to. Not as good as a PCB, but the price is right.
You mean "nest" at other side of 40-pin ribbon cable several "low-pins" breakout headers connected to several let say sensor modules ?
In this case power problem arises: each of these two 40-pin headers disposes only 2 PWR and 2 GND (please see the snapshot of schematic fragment).
So only 2 sensor modules per header can be connected this way.
I envisaged anther solution, like that realized for Zync MicroZed board: FPGA board is inserted into I/O Carrier Card that provides access to 12 Pmod-based external modules (please, see the snapshot below).
https://s9.postimg.org/ezj4a0d6z/gpio_header_layout.jpg (https://postimg.org/image/ezj4a0d6z/)
https://s9.postimg.org/5ybyz010b/micro_zed_with_io_carrier_card.jpg (https://postimg.org/image/5ybyz010b/)
