6387 Discussions
Board Test System with Arria V GX FPGA Starter Kit on 64 bit Windows 10 PC
SThac
I purchased a board  Arria V GX FPGA Starter Kit.
https://www.intel.com/content/www/us/en/programmable/products/boards_and_kits/dev-kits/altera/kit-arria-v-starter.html
I would like to run the Board Test System on 64 bit Windows 10 PC. Hence I followed the steps to setup env variables.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/support/kdb/downloads/rd01292013_416/setting_up_environment_variables_for_gui.pdf
I get the following error. In spite of the path setting, BTS seems to refer to "bin" folder instead of "bin64" folder.
C:\altera\12.1sp1\kits\arriaVGX_5agxfb3hf35_start\examples\board_test_system>java -jar bts.jar
okt 22, 2019 7:27:20 .....
INFO: Finished initialization
java.lang.UnsatisfiedLinkError: Can't load library: D:\intelFPGA\18.1\quartus\bin\sld_utiljni.dll
Greatly appreciate any help!
Note: JTAG is detected and path aslo seems to work as observed below
C:\altera\12.1sp1\kits\arriaVGX_5agxfb3hf35_start\examples\board_test_system>jtagconfig --debug
1) USB-Blaster [USB-0]
 02A030DD  5AGT(FD3H3|MD3G3)/5AGXBB3D4/.. (IR=10)
   Node 0C006E00 JTAG UART #0
   Node 19104600 Nios II #0
   Design hash   27CFECE8F0AF4DEAF4D1
 Captured DR after reset = (02A030DD) [32]
 Captured IR after reset = (155) [10]
 Captured Bypass after reset = (0) [1]
 Captured Bypass chain = (0) [1]
AR_A_Intel
Hello
Welcome to INTEL forum. May I know the Quartus version you use and there is log in the BTS directory, you can check it for the reason of the failure. Could you provide the .log file
SThac
@AAbd RAhman_Intel​ Thank you for the reply. I am using Quartus 18.1 Standard version. Following the directory structure. ".log" is not present in the BTS directrory.
Directory of C:\altera\12.1sp1\kits\arriaVGX_5agxfb3hf35_start\examples\board_test_system
2019-10-22 19:25   <DIR>         .
2019-10-22 19:25   <DIR>         ..
2013-02-21 02:39          172 032 BoardTestSystem.exe
2013-03-25 09:12        2 157 671 bts.jar
2019-10-22 19:25   <DIR>         bts_config
2019-10-22 19:25   <DIR>         bts_ddr3_hard
2019-10-22 19:25   <DIR>         bts_ddr3_soft
2019-10-22 19:25   <DIR>         bts_xcvr1_hsma_sdi
2019-10-22 19:25   <DIR>         bts_xcvr2_hsma_sma
2013-02-20 13:38          201 838 clk_cont.jar
2013-02-09 03:00          172 032 ClockControl.exe
2019-10-22 19:25   <DIR>         help
2019-10-22 19:25   <DIR>         jre1.6.0_07
2019-10-22 19:25   <DIR>         lib
2013-02-09 03:00          172 032 PowerMonitor.exe
2013-02-20 12:02          137 255 pt.jar
2019-10-22 19:25   <DIR>         sof
AR_A_Intel
May I know, have you tried BTS test with Quartus II software v12.1 SP1. The manufactured board’s BTS was built with Quartus II software v12.1 SP1. Possibly it is caused by the difference in system console of different Quartus revisions. It is suggested to use the right Quartus version with the right dev.kit version.
