5930 Discussions
Both CPU0 and CPU1 found on 5CSEBA5U23I7S (which supposed to be a single core)
MYuan2
We use cyclone V 5CSEBA5U2317S for a long time and we are sure it has a single core in MPU, it can be confirmed by cat /proc/cpuinfo (shows only cpu0) and register 0xFFD08018 (bit 0 indicates that cpu1 is not available). But we notice that the latest 5CSEBA5U23I7S we bought have dual core inside. Both FPGAs are running the same firmware but on a slightly different versions of boards. Is there any pin on HPS that can block CPU1 or does Intel give an extra core for free on Cyclone V?
sstrell
All Cyclone V SoC devices are dual core, using the same Cortex A9. Where are you seeing that this particular device is single core? CPU1 has to be enabled during the boot process, so maybe you never did that.
#iwork4intel
MYuan2
Thank you for your quick reply. Here are the links that I found in product detail, basically these two SoC are the same but 5CSEBA5U23I7 says it has 2 processor cores while the one with S says it has 1. Also the price of these 2 are different.
https://www.intel.com/content/www/us/en/programmable/products/general/selector/product-detail.html?partNumber=5CSEBA5U23I7S
Based on the Cyclone V specification (page 12 in the following link) S indicates it is a single core version.
https://www.mouser.dk/datasheet/2/612/cv_51001-1098989.pdf
We are always using 5CSEBA5U23I7S and by reading LSB of sysmgr register (0xFFD08000) we can see cpu 1 is not available (bit set to 0) in MPU in our older 5CSEBA5U23I7S. But in our recent purchased 5CSEBA5U23I7S the bit is set to 1 meaning that CPU1 is available in MPU.
We are running exactly the same firmware image (same uboot, same linux and same FPGA) so how come only the newer FPGAs enables the CPU1 not the old ones?
sstrell
I've been working with these devices for 6 years and never knew there was a single core option. I guess CPU1 is simply not available in devices with the S code. Is your question that you have newer S code devices that now show both cores available?
#iwork4intel
MYuan2
Yeh exactly ... all the older S devices (bought more than 2 years ago) we got here has only CPU 0 core but the most recent S devices we bought shows CPU0 and CPU1 are all there. I am also confused because we have been using this single core FPGA since 2014 because it is much cheaper than the dual core. The only difference we can see on the chip is that the dual core FPGAs are made in Taiwan while the single core FPGAs are made in Korea....
EBERLAZARE_I_Intel
Correct me if I am wrong, the newly ordered 5CSEBA5U23I7S(which is a single core) devices shows both cores available (CPU0 and CPU1)?
But the old 5CSEBA5U23I7S devices that you have owned, shows only one core available(CPU0)?
May I know if you are you facing any booting issues with this?
MYuan2
Yes you are right.
I don't have booting issue with 2 cores available.
EBERLAZARE_I_Intel
Thanks for the information, I will check with our internal team regarding this issue.
Is it possible for you to share the screenshot of the "LSB of sysmgr register (0xFFD08000) we can see cpu 1 is not available (bit set to 0) in MPU", for both old and new devices?
MYuan2
MYuan2
Sorry the address 0xFFD08000 is not right. I forgot to mention the offset. The correct address is 0xFFD08018 which is shown in picture above.
EBERLAZARE_I_Intel
HI,
Thanks for the screenshot, I will check with our internal team regarding this issue.
Regards.
EBERLAZARE_I_Intel
I would like to know if all your questions have been answered.
"Is there any pin on HPS that can block CPU1 or does Intel give an extra core for free on Cyclone V?"
-> Are you using Linux? You can disable the cpu 1 (even though it is not available) by root:
echo 0 > /sys/devices/system/cpu/cpu1/online
Hope this helps.
MYuan2
We are using Linux and actually we are doing this <echo 0 > /sys/devices/system/cpu/cpu1/online> to disable CPU1.
But what we are more interested in is why the two FPGAs we bought are different even serial numbers are the same.
And do we still get 2 cores with 5CSEBA5U23I7S FPGAs in the future? Because we are going to buy more.
If so, can we use the second core safely?
EBERLAZARE_I_Intel
I am still waiting for internal team to reply, can you specify how many board are involved/affected?
MYuan2
We bought at least three hundreds of 5CSEBA5U23I7S (both old and new) and we are going to buy more. So far we checked around 50 of them. All older ones has single core and newer ones have due core.
EBERLAZARE_I_Intel
Can you execute "lscpu" in Linux to display the info on the new and old device?
Is it possible to share the screenshot as well?
MYuan2
We don't have "lscpu" command in our customized Linux. We only have /proc/cpuinfo which should show similar info.
EBERLAZARE_I_Intel
Is there any way you could check the core count of the device from your customized Linux?
MYuan2
Isn't /proc/cpuinfo enough? If not we can try to integrate lscpu
MYuan2
Besides cpuinfo here is dmesg info in our system, the following one shows the system found 2 cores:
# dmesg
Booting Linux on physical CPU 0x0
Initializing cgroup subsys cpuset
Linux version 3.10.31-ltsi (deva@deva-desktop) (gcc version 4.9.3 (Buildroot 2015.11-ga9b17cc-dirty) ) #3 SMP Mon Nov 18 09:11:44 CET 2019
CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=10c5387d
CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: Altera SOCFPGA, model: Altera SOCFPGA Cyclone V
Memory policy: ECC disabled, Data cache writealloc
On node 0 totalpages: 131072
free_area_init_node: node 0, pgdat 80961840, node_mem_map 8099f000
 Normal zone: 1024 pages used for memmap
 Normal zone: 0 pages reserved
 Normal zone: 131072 pages, LIFO batch:31
PERCPU: Embedded 8 pages/cpu @80dab000 s10688 r8192 d13888 u32768
pcpu-alloc: s10688 r8192 d13888 u32768 alloc=8*4096
pcpu-alloc: [0] 0 [0] 1
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 130048
Kernel command line: console=ttyS0,115200 root=/dev/mtdblock1 rw rootfstype=jffs2
PID hash table entries: 2048 (order: 1, 8192 bytes)
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Memory: 512MB = 512MB total
Memory: 509792k/509792k available, 14496k reserved, 0K highmem
Virtual kernel memory layout:
  vector : 0xffff0000 - 0xffff1000  (  4 kB)
  fixmap : 0xfff00000 - 0xfffe0000  ( 896 kB)
  vmalloc : 0xa0800000 - 0xff000000  (1512 MB)
  lowmem : 0x80000000 - 0xa0000000  ( 512 MB)
  modules : 0x7f000000 - 0x80000000  ( 16 MB)
   .text : 0x80008000 - 0x80523014  (5229 kB)
   .init : 0x80524000 - 0x809319c0  (4151 kB)
   .data : 0x80932000 - 0x80964810  ( 203 kB)
    .bss : 0x80964810 - 0x8099ebec  ( 233 kB)
SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
Hierarchical RCU implementation.
NR_IRQS:16 nr_irqs:16 16
sched_clock: 32 bits at 100MHz, resolution 10ns, wraps every 42949ms
Console: colour dummy device 80x30
Calibrating delay loop... 1594.16 BogoMIPS (lpj=7970816)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
ftrace: allocating 14872 entries in 44 pages
CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
Setting up static identity map for 0x803b5fa0 - 0x803b5fd4
CPU1: Booted secondary processor
CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
Brought up 2 CPUs
SMP: Total of 2 processors activated (3188.32 BogoMIPS).
CPU: All CPU(s) started in SVC mode.
MYuan2
Here is the Dmesg log from single core FPGA:
Linux version 3.10.31-ltsi (deva@deva-desktop) (gcc version 4.9.3 (Buildroot 2015.11-ga9b17cc-dirty) ) #2                                          SMP Fri Oct 4 14:40:33 CEST 2019
free_area_init_node: node 0, pgdat 80973840, node_mem_map 809b1000
PERCPU: Embedded 8 pages/cpu @80dbd000 s10688 r8192 d13888 u32768
Memory: 509720k/509720k available, 14568k reserved, 0K highmem
   .init : 0x80524000 - 0x809439c0  (4223 kB)
   .data : 0x80944000 - 0x80976810  ( 203 kB)
    .bss : 0x80976810 - 0x809b0bec  ( 233 kB)
CPU1: failed to come online
Brought up 1 CPUs
SMP: Total of 1 processors activated (1594.16 BogoMIPS).
