imagetool.c:(.text+0xa): undefined reference to `__stop_image_type'
/usr/bin/ld: imagetool.c:(.text+0x12): undefined reference to `__start_image_type'
/usr/bin/ld: tools/imagetool.o: in function `imagetool_verify_print_header':
imagetool.c:(.text+0x73): undefined reference to `__stop_image_type'
/usr/bin/ld: imagetool.c:(.text+0x7a): undefined reference to `__start_image_type'
collect2: error: ld returned 1 exit status
make[1]: *** [scripts/Makefile.host:104: tools/dumpimage] Error 1
make: *** [Makefile:1900: tools] Error 2
Hi Snehal
Just to update the forum case.
The missing steps from the RBO page are the steps below:
1.Step to convert the sof to rbf. You could use the command below to convert the sof.
quartus_cpf -c -o bitstream_compression=on soc_system.sof soc_system.rbf
2.Missing u-boot.scr could be gotten from the gsrd page.
https://releases.rocketboards.org/2025.03/gsrd/c5_gsrd/u-boot.scr
3.Place both rbf and the u-boot.scr in the sdcard partition 1 (sdfs)
Jingyang, Teh
- « Previous
- 1
- 2
- Next »
Hello Jingyang Teh,
Can you please share pointers regarding dts file generation for customized board using Quartus Prime 22.1 Standard version tool.
snehal_p
Hi
The sopc2dts tool have been discontinued.
Currently, all device tree example are created and stored in the uboot branch and linux branch (arch/arm/dts/socfpga_cyclone5_socdk.dts).
It is advisable to make changes to the devkit device tree.
Are you using 2 different UART baudrate for the linux and uboot?
Can you share me both linux and ubiit device tree to me?
Jingyang, Teh
Thanks and regards,
snehal_p
Hi
In the new flow the sopc2dts generator have been discontinued and should no be used.
You will have to make the changes base on the devkit device tree located in the location :
Jingyang, Teh
Hi
Do you have any more follow up question on this issue?
Jingyang,Teh
Hi
Since there are no feedback for this case, I shall set this case to close pending. If you still need further assistance, you are welcome reopen this case within 20days or open a new case, someone will be right with you.
If you happened to close this case you will receive a survey. If you think you would rank your support experience less than 4 out of 5, please allow me to correct it before closing or if the problem can’t be corrected, please let me know the cause so that I may improve your future service experience.
Jingyang
Case reopening.
case reopening
Hi Snehal
Jingyang, Teh
Hi
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com/s/?language=en_US’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Jingyang, Teh
- « Previous
- 1
- 2
- Next »
