5930 Discussions
Bus error on memory operation
I have a Cyclone V SoC dev kit and I get the following errors when trying to load it onto the board:
ERROR(CMD16-TAD216-NAL18):
! Failed to load "DPD_Ex.axf"
! Failed to write 82,792 bytes to address S:0x00008000 while writing block of 4,096 bytes to address S:0x00008000
! Bus error on memory operation.
Any ideas what is going on? How to fix it?
I suspect you are tring to fit a quart into a pint pot.
The 82k looks like a standard bsp build that includes a printf(), it will only fit into external memory.
Address 0x8000 is probably a small internal memory block.
You need to look at which memory areas the code/date/stack are assigned to.
Altera really ought to change the default examples to use the small bsp.
I am running bare-metal, I have a .s file where I set those memory address. Do you know of a Doc where I can know what the memory address of the Cyclone board are?
--- Quote Start ---
--- Quote End ---
I am trying to execute the same bare-metal program (the one described in the user guide) on my Cyclone V SoC development kit and facing same error. Here is the message :
loadfile "D:\TOOLS\altera\130sp1\embedded\ds_5_teast_wb\Altera-SoCFPGA-HelloWorld-Baremetal-GNU\hello.axf
Target Message: Memory access caused precise abort.
Debug Precise Abort Registers : DFSR = 0x00000817, DFAR = 0xFFFF1000
! Failed to load "hello.axf"
! Failed to write 16,048 bytes to address S:0xFFFF0000 while writing block of 4,096 bytes to address S:0xFFFF1000
Will you please explain me how you solved this problem?
Ashish
Like, the answer given above says. Your file is too big for the space.
--- Quote Start ---
--- Quote End ---
Yeah, that I know very well. But, what should I do to execute this bare-metal program successfully?
I am facing same error.
Thank you very much!
