I have a Cyclone V SoC dev kit and I get the following errors when trying to load it onto the board: ERROR(CMD16-TAD216-NAL18): ! Failed to load "DPD_Ex.axf" ! Failed to write 82,792 bytes to address S:0x00008000 while writing block of 4,096 bytes to address S:0x00008000 ! Bus error on memory operation. Any ideas what is going on? How to fix it?Link Copied
I suspect you are tring to fit a quart into a pint pot.
The 82k looks like a standard bsp build that includes a printf(), it will only fit into external memory. Address 0x8000 is probably a small internal memory block. You need to look at which memory areas the code/date/stack are assigned to. Altera really ought to change the default examples to use the small bsp.- Mark as New
I am running bare-metal, I have a .s file where I set those memory address. Do you know of a Doc where I can know what the memory address of the Cyclone board are?
--- Quote Start --- Hello, I have a Cyclone V SoC dev kit and I get the following errors when trying to load it onto the board: ERROR(CMD16-TAD216-NAL18): ! Failed to load "DPD_Ex.axf" ! Failed to write 82,792 bytes to address S:0x00008000 while writing block of 4,096 bytes to address S:0x00008000 ! Bus error on memory operation. Any ideas what is going on? How to fix it? --- Quote End --- Hi, I am trying to execute the same bare-metal program (the one described in the user guide) on my Cyclone V SoC development kit and facing same error. Here is the message : loadfile "D:\TOOLS\altera\130sp1\embedded\ds_5_teast_wb\Altera-SoCFPGA-HelloWorld-Baremetal-GNU\hello.axf" Target Message: Memory access caused precise abort. Debug Precise Abort Registers : DFSR = 0x00000817, DFAR = 0xFFFF1000 ERROR(CMD16-TAD216-NAL18): ! Failed to load "hello.axf" ! Failed to write 16,048 bytes to address S:0xFFFF0000 while writing block of 4,096 bytes to address S:0xFFFF1000 ! Bus error on memory operation. Will you please explain me how you solved this problem? Ashish
Like, the answer given above says. Your file is too big for the space.
--- Quote Start --- Like, the answer given above says. Your file is too big for the space. --- Quote End --- Yeah, that I know very well. But, what should I do to execute this bare-metal program successfully?
I am facing same error. Will you please explain me how you solved this problem? Thank you very much!
