Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Honored Contributor I
Buying a Dev Kit
I want to buy a development kit with an ethernet interface 10/100. I could buy a Cyclone III dev board ($199) and a daughter board (hsmc) with an ethernet port but i'm not sure if it's the cheapest option. Also I want to run uClinux with this board. What do you recommend?.
Highlighted
Hello
Check the price of DE2 kit from Terasic Technologies. He is based on a Cyclone II, but board have more features than kit with Cyclone III.
Best regards
Highlighted
Thanks Komi for your response. I took a look at terasic site and i like the DE70 board. Does it has an altera's license key to compile and create configurations files for the FPGA?.
Ivan
Highlighted
Hello
If I understand well your question you are asking about development software. Quartus Web Edition is available for free. You may create configuration file etc.
Regarding DE2-70 this kit consist the biggest version of Cyclone II - I mean number of multipliers, logic cells etc.
Best regards
