CG5 NET demonstration
I'm trying to run the CG5_NET demnstration example on my Cyclone V GX Starter Kit board with an ETHERNET-HSMC Card add-on.
If I run the demo_batch files, I can succesfully run only with a 100Mb connection. If I connect to a 1000Mb connection I cannot get an IP address from the DHCP server.
Furthermore, I cannot re-compile the design without errors neither with QuartusII 13.1 (web edition) nor with QuartusII 13.0Sp1 (web edition).
There is someting I'm missing?
Thank you
