5541 Discussions
CX4-to-HSMC Adapter on Arria-II GX
I am trying to connect a CX-4 cable with the Arria-II GX FPGA Development Kit. The description for the CX4-to-HSMC Adapter (http://www.altera.com/products/ip/ampp/morethanip/morethanip.html?gsa_pos=2&wt.oss_r=1&wt.oss=cx4-to-hsmc%20adapter) indicated that it is compatible with Altera Stratix-II GX development mainboards.
I am wondering is the same adapter card compatible with the Arria-II GX FPGA board as well?
Thank you
I have ordered a couple of these adapters to be used with the Arria II GX kit as well. I shall find out soon... but I am wondering what you may be suspecting in terms of compatibility. Because, both the sides of the adapter are standard. i.e. hsmc and cx4. Are you thinking that the cx-4 pins may not be connected to the correct transceivers on the a2gx board?
-sanjay
--- Quote Start ---
-sanjay
--- Quote End ---
I'm curious about how it works for you, too. I have a few of the adapters that I may want to use with new dev kit.
One quirk with the adapter was that the tx polarity was flipped so I had to force tx_invpolarity in FPGA design. Wondering if that's still the case with the adapter you got.
Thanks!
Got them and tried them on the Arria II GX. They work. Looks like they fixed the tx polarity.
--- Quote Start ---
--- Quote End ---
That's good to know. Thanks!
