the example on rocketboards site has POF file only
Hello
Welcome to INTEL forum. May I know the reason you request the sources for System Max V. Could you help elaborate more on your request.
Since all peropheral connected to A10 through the MAX V, I would like to know how it is connected to these peripheral.
to be more specific I would like to connect UART DB9 (J35) to A10 (U23).
So I need Either a document to suggest the pins in/out of A10 (U23) to connect this peripheral.
thanks
Noam
Hello
Regarding you request for sources System Max V, I will refer this to board team member. Please give me some time and I will get back to you with an update.
May i know what is the application with UART? Based on my understanding, You may connect it to another I/O pin on the FPGA
In our project we would like to buildin parallel to the HPS also NIOS2 with peripherals such as UART (different than the one connected for linux J10 UART1).
So the next candidate can be J25 DB9. In schematics J25 connected to Max V.
How is it connected to U23 A10? to which pins?
thanks,
Noam
Hello Sir,
Yes, you can connect to any pin to the HPS.
