5407 Discussions
Can't build a project template
Hi everybody,
I have a development kit, cyclone II and I download a Nios II/s processor on it thanks to the hardware developement tutorial.
I tried to run a couple of software templates, most of them worked well. But the "boading diagnostics" and the "memory test" didn't even build correctly. I have this error:
Description Resource Path Location Type
In function `GetInputString': board_diag.o board_diagnostics/obj 0 C/C++ Problem
In function `MenuEnd': board_diag.o board_diagnostics/obj 0 C/C++ Problem
In function `SevenSegControl': board_diag.o board_diagnostics/obj 0 C/C++ Problem
In function `TestLEDs': board_diag.o board_diagnostics/obj 0 C/C++ Problem
make: *** [board_diagnostics.elf] Error 1 board_diagnostics 0 C/C++ Problem
undefined reference to `getc' board_diag.c board_diagnostics 114 C/C++ Problem
undefined reference to `sscanf' board_diag.c board_diagnostics 141 C/C++ Problem
undefined reference to `sscanf' board_diag.c board_diagnostics 313 C/C++ Problem
undefined reference to `sscanf' board_diag.c board_diagnostics 653 C/C++ Problem
I think the Software Build Tools for Eclipse does not find the <stdio> library...
Could anyone help me please?
i have the same problem too ..
I am building a simple LED test pattern from "Board diagnostics" and selecting my own system (created my SOPC builder in Quartus II).
After that I go to the "system library properties" and change the setting to "program never exits" and "small C library".
when i build them , i got below error message.
Description :
In Fuction 'GetInputString' : board_diag.o
in Function 'main' : board_diag.o
undefined reference to 'getc' : board_diag.c
undefined reference to 'sscanf' : board_diag.c
