5931 Discussions
Can't generate 20Mhz clock from Cyclone III Starter Kit
I'm using the Cyclone III Starter Kit along-with some ADC & DAC chips. These chips demand a 20 MHz input clock, which I intend to generate from my Starter board.
After going through the "my_first_fpga_tutorial" - it seemed quite simple to me : Just have an ALTPLL megafunction generate the 20 Mhz output from the 50 Mhz clock input. (osc_clk: Pin_V9)
I tried that, and assigned the generated output clocks to the "HSMC_CLKOUT_n2" & "HSMC_CLKOUT_p2" pins (they are dedicated clock output pins I guess)
I used the same code for the TimeQuest SDC file, as is given in the tutorial (since i've yet to learn what this is):
create_clock -period 20.000 -name osc_clk osc_clk
derive_pll_clocks
derive_clock_uncertainty
Now I test the corresponding output pins on the oscilloscope, but all I see is a very jittery signal (can't trigger it stable on the scope by any means), with a very low frequency (about 100 Hz).
Can anybody help ?
Ohh ... turns out that I got too hasty in putting up the above post. Its my mistake.
The silly thing was, that with my original oscilloscope X-axis setting put to (20 ms / div), the signal was still appearing 5 divisions periodic, but jittery -which led me into believing that something was wrong.
But just after I posted the above message, I checked correcting the X-axis setting to (10 ns / div) and now the signal turned out to periodic again with 5 divisions ( = 10*5 = 50ns => 20 Mhz), and this time .. stable as well
Couldn't find any option to delete my previous post, hence this apology. Sorry !
(perhaps the admin can delete this thread to avoid further confusions)
you are not the first one, and woun't be the last with such a mistake.
and we all learn from mistakes, if we read and understand.
so lets keep your posting for others to learn :-)
