5930 Discussions
Can the CPLD EPM7128AELC84-10 be compiled for with Quartus Prime?
JFeld4
I have a GDF file that was used to build the POF file we use to program EPM7128AELC84-10s. However I don't have a compatible project file of any type to open with either Quartus Prime or Quartus II so I'm unable build new working versions of the POF file. How to I go about setting up a project that will correctly build the GDF file into a POF that will work on EPM7128AELC84-10?
AnandRaj_S_Intel
No, the Quartus® II software does not support MAX 7000 devices.
The Quartus II programmer cannot be used to program MAX 7000 devices.
The Quartus II software and programmer supports MAX 7000AE, MAX 7000B and MAX 7000S devices.
Your are using Max7000A device, which is supported by MAX+PLUS II software that provide compiler, simulation, and programming with byteblaster capabilities as per below link.
https://www.intel.com/content/www/us/en/programmable/support/support-resources/support-centers/devices/programming-tools/tls-altera-software.html
https://forums.intel.com/s/question/0D50P00003yyKE8SAM/problem-with-programmer-max-7000a
You can download tools from below links.
https://www.intel.com/content/www/us/en/programmable/support/support-resources/download/legacy/maxplus2/upd-maxplus2_index.html
https://www.intel.com/content/www/us/en/programmable/downloads/download-center.html
MAX+PLUS® II software is intended only to support legacy designs. Not recommended for new designs
Anand
