Arria V Device Overview(AV-51001) says the input reference clock ranges from 27MHz to 710MHz.
Hi Srikanth,
Yes, you can have a 25 MHz or 50 MHz system/global clock for FPGA. And use PLL to generate the required clock frequency for other design modules (ddr/transceivers/ADC).
Refer respective datasheet under the clock-tree session.
Let me know if this has helped resolve the issue you are facing or if you need any further assistance.
Anand
Datasheet says global or regional clock frequency is either 625 or 525 MHz only. (Document ref: AV_51002, Page No 44).
That is a max frequency that you can have for the global or regional clock.
- You can have a 25 MHz or 50 MHz system/global clock for FPGA. And use PLL to generate the required clock frequency for other design modules
![](/skins/images/334123A3FE773EFF4A2FEF297F35881D/responsive_peak/images/icon_anonymous_message.png)
Topic Options
