6339 Discussions
[Case:567384] California 65 information
MSale2
[Case:567384]
Please help me with the following points:
- According to the attached Material Declaration "en6337qi_20190718233352_v1.xml" there are one or more substance "Carbon Black@Ni@NiO"from the prop 65 chemical list found in this part "EN6337QI" but we need to confirm if the substances for each component are above or below the safe harbor level or if you follow with prop 65 requirements and provide (clear and reasonable warning) for the products that contain prop 65 substances list or not.
- According to the attached Material Declaration "epm1270f256i5n_20180720203830_v1.xml" there are one or more substance "Carbon Black@Arsenic@Ni"from the prop 65 chemical list found in this part "EPM1270F256I5N" but we need to confirm if the substances for each component are above or below the safe harbor level or if you follow with prop 65 requirements and provide (clear and reasonable warning) for the products that contain prop 65 substances list or not?
(Virus scan in progress ...)
NurAiman_M_Intel
Hi Salem,
Thank you for contacting Intel Community.
Please be noted that Intel FPGA is compliant with RoHS II (No. 2011/65/EU). You can find the related information from the following link:
https://www.intel.com/content/www/us/en/programmable/support/quality-and-reliability/environmental/lead-free/rel-lead-free.html
Hope this will clarify. Please inform me if there is any further information required.
Aim
