Case?
Can anyone help me shorten this if into a case ?
Is it smart?
-- Signaltap end PROCESS (CLOCK_50, KEY(0), KEY(1)) BEGIN IF (CLOCK_50'EVENT AND CLOCK_50 = '1') THEN -- Trigger Condition IF KEY(0) = '0' AND KEY(1) = '0' THEN q <= q; ELSE IF KEY(0) = '1' AND KEY(1) = '0' THEN q <= '1'; -- Set ELSE IF KEY(0) = '0' AND KEY(1) = '1' THEN q <= '0'; -- Reset END IF; END IF; END IF; END IF; END PROCESS;
PROCESS (CLOCK_50)
BEGIN
q <= '1'; -- Set
ELSIF KEY(0) = '0' AND KEY(1) = '1' THEN
q <= '0'; -- Reset
ELSE
null;
END IF;
END IF;
END PROCESS;
--- Quote Start ---
--- Quote End ---
PROCESS (CLOCK_50) -- Key() should not be in the list , KEY(0), KEY(1)) variable KeyCode: natural range 0 to 3; BEGIN IF (CLOCK_50'EVENT AND CLOCK_50 = '1') THEN -- Trigger Condition -- Assuming that Key is a std_logic_vector and possibly longer than -- just two bits. KeyCode := to_integer(unsigned(Key(1 downto 0)); case KeyCode is when 1 => q <= '1'; -- Set when 2 => q <= '0'; -- Reset when others => null; end case; END IF; END PROCESS;
--- Quote Start ---
Is it smart?
--- Quote End ---
No it is not smart...people can be smart, but 'it' cannot.
Kevin Jennings
