5922 Discussions
Changing the degrees the BeInMotion kit rotate
So far I'm new in programming FPGAs and using the Quartus , Qsys and Nios. I tried to change all the values in the void turn_left() but returned empty handed. So far I'm grasping the basics but i'm pretty it is in that function. I want it to rotate from 90 degrees to around 45 deg. so that it will be smoother. Here's the code
int turn_left()
int dc_m1_pwm_duty = dc_m1_pwm_freq/4;
int dc_m2_pwm_duty = dc_m2_pwm_freq/4;
dc1_cmp = 1;
dc2_cmp = 1;
IOWR(IR_RX2_BASE,0x00,0);
IOWR(IR_RX1_BASE,0x00,0);
IOWR(DC2_PWM2_BASE+0x08,0,0);
IOWR(DC1_PWM1_BASE+0x08,0,0);
IOWR(DC2_PWM1_BASE,0,dc_m2_pwm_freq);
IOWR(DC2_PWM1_BASE+0x04,0,dc_m2_pwm_duty);
IOWR(DC1_PWM2_BASE,0,dc_m1_pwm_freq);
IOWR(DC1_PWM2_BASE+0x04,0,dc_m1_pwm_duty);
IOWR(IR_RX2_BASE,1,722);
IOWR(IR_RX1_BASE,1,722);
IOWR(IR_RX2_BASE,0x00,1);
IOWR(IR_RX1_BASE,0x00,1);
IOWR(DC1_PWM2_BASE+0x08,0,1);
IOWR(DC2_PWM1_BASE+0x08,0,1);
while(1)
if(( dc1_cmp ==0 ) && (dc2_cmp ==0 ))
return 0;
else
usleep(90000);
dc_m1 = IORD(IR_RX1_BASE,1);
dc_m2 = IORD(IR_RX2_BASE,1);
i = dc_m1-dc_m2;
j = dc_m2-dc_m1;
if(i > 5) {
if(dc_m2_pwm_duty >= 100)
dc_m2_pwm_duty-=50;
if(dc_m1_pwm_duty < 850)
dc_m1_pwm_duty+=50;
else
if(j > 5) {
if(dc_m1_pwm_duty >= 50);
dc_m1_pwm_duty-=50;
if(dc_m2_pwm_duty < 1700)
dc_m2_pwm_duty+=50;
Hope someone and I'll appreciate it. Thank you in advance.
