Hi everybody,
I am doing a projects that use GPS module sim900 to communicate with FPGA DE2. The module sim900 has 1 UART interface to command out, simply it has only 3 lines RXD and TXD and ground. I designed a system-on chip based ARM and some interfaces (of course it has UART as well), and then loading design into DE2 kit. I connected 3 lines of UART interface from sim900 with 3 GPIO pins (UART in my design used GPIO from board), but not sure why I cannot get any signal back after turning on the sim900 circuit. I also test separately sim900 + PC and my design + PC and they are working normaly. Anybody has experience on this case. Many thanks... Regards,Link Copied
Have you tested the RS232 independent of the GPS unit?
